Isolated Triac Control Circuit MOC3020
| Updated on June 21, 2014
Triac (btb08-600) PIC controller, CMOS, TTL and so on. With such integrated devices designed to control high power. MOC3020 triac driver photo provided by the motor insulation, such as a lamp devices can be controlled.
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
btb08-triyak-moc3020-foto-triyak-devresi
Source: http://www.soloelectronica.net/rele_solido.htm
Publication date: 2010/09/22 Tags: ,
1 Comment “Isolated Triac Control Circuit MOC3020
    230V LED Lighting Lamp Transformerless Circuit
    Circuit have not tried but proteus isis on the set up and necessary to try other resistor capacitor limiting circuit according to looks better than circuit 123 pcs white LED 230v mains voltage rectified dc voltage is being run with + voltage directly to the LEDs – the BD711 and BC547 transistors goes out.
    Transformerless LED Lighting Lamp Circuit 230V
