100 watts Hi-Fi Amplifier Circuit MJL21194 MJL21193
| July 7, 2023 Updated
MJL21193 MJL21194 transistor 100 watts Hi-Fi Amplifier Circuit DC + -36 volts symmetrical supply is working with circuit diagrams and sprint layout prepared by the PCB drawing there. Lay uzntıl pcb file and take a printout for the Sprint-Layout-Viewer can use the program
100W Hi Fi Amplifier Circuit
100watt-mjl21193-mjl21194-ile-100w-hifi-anfi-devresi
mjl21193-mjl21194-ile-100w-hifi-anfi-devresi-proba
Source: www.hobbielektronika.hu 100W Hi-Fi Amplifier Circuit pcb MJL21194 MJL21193 alternative link:
Published: 2008/04/08 Tags: ,
1 Comment “100 watts Hi-Fi Amplifier Circuit MJL21194 MJL21193
    20AMPS 200AMPS Battery Charger Circuit
    Circuit bit confused 🙂 but very powerful and has nice features automatic protection circuit PWM current control is doing the reverse link and a quick charge system has a heat protection
    The type of a battery: Acid lead battery Nominal filling tenseness: 12V Capacity which can be spent: 20..200Ah Charging current: 0..20A [C/10=@100percnt] Filling tenseness: Acid temperature compensation (optionally automatic) -30mV/°C @14,2V
