Microchip pic12cxxx key, timing circuits cog of the PIC12C508 based on the c series instead F series, available in the most simple circuits in some schemes no other software information thanks schemas can be used with all circuits, software assembly prepared with a detailed description (in English) and flow diagram There microchip company sample applications.
Between the circuit’s very simple to understand, especially for people who are new to pic programming a useful resource.
PIC Micro Key, Switch circuits
beepers in electrical
Bright Idea Light Timer Junior
Connecting Sensor Buttons to PIC12CXXX MCU
Electronic Key Button Dimmer and Potentiometer Dimmer Controller
Freezer Protector
Implementing Software Timer Interrupts
Light Switch with Delay Turn-Off
Net Switch
Optical Pyrometer
Programmable Lights
Replacing Electromechanical Switches
Smart Switch for Automotive Applications
Smart Switch for Car Windscreen Wiper Control
Smart Turn Signal Blinker
Transmission Sensor for Remote Car Starter
Triple Input Inverting Debounce Circuit
PIC Micro Timing Timer circuits
99 Minute Timer
Darkness Controller for Poultry
Lawn Sprinkler System Using a PIC12C508
Maxi Functions Micro Chip
PIC12C508 Based Timer
Programmable Timer with Time Correction Circuit
Reminder Timer for Changing Chemicals Water Softener
Solutions Cubed Real-Time Clock
The Galactic Timer
Time Delay Relay Family
Timer Controllers
Microcohip examples download:
Published: 2009/11/21 Tags: microchip projects, microcontroller projects
KS0108 LCD Thermometer CCS C PIC16F88 LM35 Sensor
Thermometer circuit LM35 temperature sensor with 2 PIC16F88 based on temperature information kc0108 128 × 64 graphic LCD displays on
Very simple thermometer with PIC16F88, two LM35 sensors and KS0108 graphic LCD. Schematic from Proteus VSM. Note that almost every pin of PIC16F88 is used.
Here’s the source code, I’m sorry it isn’t commented very well. The code is written for CCS C compiler. There’s also Proteus VSM simulation file and compiled hex file.
LCD Thermometer
