two different circuits happen to have 555 timer integrated with the structures and mc 34063 switching control integrated with the circuit used in the transformer television or monitor EHT transformer originally intended use in car air filter, carburetor something to do with the car but know much about because I have not figured business people who know from the pictures more or less solves
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
NE555 High Circiut Voltage Generation
MC34063 Circiut High Voltage Generation
source http://ha-lab.narod.ru High Voltage Generation Circuits schematic pcb files alternative link
Published: 2009/05/04 Tags: 555 timer circuits, power electronic projects
PIC18F452 Infrared Radar Circuit GP2D120 Sensor
Led indicator circuit short-range radar sensor that is used gp2d120 sharp pic 18f452 microcontroller software in C language Hi-Tech c with LEDs 74HCT373 integrated infrared sensor with pic GP2D120 a good example to use ..
Sharp GP-2D120 features
• Analog output
• Effective range: 4 30 cm
• Typical response time: 39 MS
• Typical start up delay: 44 MS
• Average current consumption: 33 mA
Radar circuit
