LTspice XVII is a schematic, circuit simulation program. LTspice has gone through a full rewrite process to improve the simulator’s performance, fix bugs, and expand the simulator to run industry-standard semiconductor and behavior models. A digital simulation feature has been added, including co-simulation. Extensive enhancements have been made to the analog SPICE simulator, such as parallel processing and dynamic assembly and object code generation in the SPARSE matrix solver to make LTspice XVII the industry’s ultimate analog simulator.
Many Linear Technology products are modeled with proprietary building blocks and / or proprietary hardware definition languages that accurately incorporate realistic behavior with special macromodels. This enables rapid prototyping of an SMPS by simulation.
LTspice is designed to be used as your general purpose SPICE simulator. New circuits can be prepared with built-in schematic capture. Simulation commands and parameters are placed as text in the diagram using the generated SPICE syntax. Waveforms and device currents of circuit nodes can be drawn by clicking the mouse on the nodes in the schematic during or after simulation.
LTspice is a high performance SPICE simulation software, waveform viewer with models and enhancements to facilitate schematic capture and simulation of analog circuits. Includes macromodels for LTspice’s switching regulators, amplifiers and a device library for general circuit simulation. There is a detailed help document on the use of Ltspice.
LTspice XVII includes a general purpose schematic capture program. It allows you to draw diagrams, create symbols, create network lists and cross probe simulation data. Unlimited schematic size and hierarchy are supported.
LTspice XVII includes an integrated waveform viewer that gives you full control over how the simulation data is drawn.
Basic Schematic Editing The schematic capture program is used to create new schemes or replace the provided sample circuits. Circuit size and depth of hierarchy are limited only by computer resources.
LTspice direct download link: ltspice.analog.com/software/LTspiceXVII.exe
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-26391a.zip
Publication date: 2020/02/06 Tags: electronics software tools
Téléchargement du programme LTspice
LTspice XVII est un programme schématique de simulation de circuits. LTspice a subi un processus de réécriture complet pour améliorer les performances du simulateur, corriger les bogues et étendre le simulateur pour exécuter des modèles de semi-conducteurs et de comportement standard de l’industrie. Une fonction de simulation numérique a été ajoutée, y compris la co-simulation. De nombreuses améliorations ont été apportées au simulateur analogique SPICE, telles que le traitement parallèle et l’assemblage dynamique et la génération de code objet dans le solveur de matrice SPARSE pour faire de LTspice XVII le simulateur analogique ultime de l’industrie.
De nombreux produits de technologie linéaire sont modélisés avec des blocs de construction propriétaires et / ou des langages de définition de matériel propriétaires qui incorporent avec précision un comportement réaliste avec des macromodèles spéciaux. Cela permet un prototypage rapide d’un SMPS par simulation.
LTspice est conçu pour être utilisé comme votre simulateur SPICE à usage général. De nouveaux circuits peuvent être préparés avec une capture schématique intégrée. Les commandes et paramètres de simulation sont placés sous forme de texte dans le diagramme à l’aide de la syntaxe SPICE générée. Les formes d’onde et les courants d’appareil des nœuds de circuit peuvent être dessinés en cliquant avec la souris sur les nœuds du schéma pendant ou après la simulation.
