Microchip PIC ARM Atmel AVR mcu Then now advanced usage increases in prices now counted most. Mostly for beginners without much additional hardware can be developed several projects already considered a factor ARM chip away at the beginning Elektroemr simple but useful for my brother LPC134 LPC134 has designed a test card for you can try the code you write.
Experiment card LPC1343 features; LPC134 pins for the header, Micro SD card slot, mini-USB socket, via USB or optional external 5V operation (3.3-volt regulator), 12 Mhz Crystal, USART header output, LED indicators, reset button, ISP jumper (USB and USART bootloader to activate)
Source: blog.mikrorf.com alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16068.zip
Published: 2011/08/27 Tags: avr development board, development board projects
Led Signboards For Animated Frame Circuit PIC12F675
Hello electronics lovers ..
Course is always good to give a breath between the short. LED signage and LED together this short animation of a program can be useful to those dealing with the isis schematic and printed circuit board hexkod I’m sending.
Led to animate its function will be useful for those who use a animaskart. In a well designed frame animation cards are available rotate feature or design my own card that I do not have this feature, but this feature is available for our advertisers using cards or hobby purposes it would be useful to regulate the LED animation.
