Experiment Kit For LPC1343 ARM (Breakout Board)
| Updated on August 3, 2019
Designed for embedded applications LPC1343 ARM Cortex-M3 microcontroller low-power on-chip peripherals include UART and USB bootloader I2C, SPI, UART, Timers, Interrupt, ADC, etc.. There are a lot of features
A very ARM LPC1343 on the test kit can be used on a breadboard project can be tested
eagle-schematic-lpc1343-arm-breakout-board-120x120
USB interface and Power Supply ISS Switches, Reset and ISP switches, LED indicators, etc. Bootloader Interface Selector. ‘s. Test circuit diagram of ARM source eagle, pcb files there …
lpc1343-arm-breakout-board-eagle-3d
pcb-lpc1343-breakout-board
source: voltsandbytes.com/lpc1343-breakout-board/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21937.zip
Publication date: 2013/08/05 Tags: ,
2 Comments “Experiment Kit For LPC1343 ARM (Breakout Board)
    Atmega88 IR2184 DC Servo Motor Driver Circuit
    DC Servo motor driver circuit based on the microcontroller atmel atmega88 outputs half bridge driver IC Ir2184 is being used with this integrated works at a frequency of 16MHz DC servo Irf540 MOSFETs atmega88 drive circuit PCB design looks great eağle have the source schema and pcb drawings are prepared with atmega88 for non-source code projects usually granted the .hex dosyasıda do not share but this circuit can inspire very well designed hardware 😉
    u>Experimentierboard Für LPC1343 ARM (Ausbruch-Brett)
    Konzipiert für embedded-Anwendungen LPC1343 ARM Cortex-M3 mikrocontroller mit low-power-on-chip-Peripherie gehören UART-und USB-bootloader I2C, SPI, UART, Timer, Interrupts, ADC, usw… Es gibt eine Menge von Funktionen
    Ein sehr LPC1343 ARM auf der test-kit kann verwendet werden, auf einer Lochraster-Projekt getestet werden
