ARM-based rapid prototyping for custom designs or LPC11U35FHI33/501, ARM M0 that is built on a microprocessor card handy to complete the schema is completed and all source files for PCB drawings, samples a given project…
In addition, a smaller version of the card you see in the pictures (tiny arm)
MCU: NXP ARM M0 LPC11U35FHI33 / 501 64K flash memory, 8K RAM, 4K EEPROM 48MHz speed
Core voltage: 3.3 V (for 3.3 V LDO regulator built in)
MCU Package: QFN 5x5mm, 0.5 mm pitch 32
PCB dimensions 1.5 “x 0.775” (19.7 mm x 38.1 mm)
2 layers PCB
1mm PCB Thickness (recommended) (standard 1.6 mm ).
Eagle PCB CAD File format + PDF + Gerber files.
Technology, SMD 0402, 0.5 mm pitch QFN.
Power Options, USB, internal 3.3 V, with 3.3 V LDO regulator (inclusive) max external 16V
2×15 header pins, DIP, 0.7 “row spacing. All MCU I / O pins to access.
Micro B USB connection
Debugger connector SWD 2×5 pin header, 0.5
(Operation for MCU-48MHz) 12mhz crystal.
LEDs power (blue) USB status (Yesil), Application (red),
NXP LPCXpresso IDE (Eclipse-based, free)
arm development board
source: github.com/zapta/arm/tree/master/pro-mini alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-25438.zip
Published: 2016/04/22 Tags: development board projects
Handmade membrane keypad, and the Arduino application
The author has done a beautiful job with handmade membrane is quite an original view is a little tricky, but it works in the prototype experiments, a thin copper foil pieces of the paper it’s printed … wiring diagram of the necessary connections being made that is being cut and pasted.. in addition, there is an Arduino example code to test the keypad membrane.
Arduino membrane keypad
LPC11U35FHI33 ARM-Experimentierboard Leiterplatte
ARM-basiertes rapid prototyping für individuelle designs oder LPC11U35FHI33/501, ARM M0, basiert auf einer Mikroprozessor-Karte handy, um das schema abgeschlossen ist und alle Quell-Dateien für Leiterplatten-Zeichnungen, Proben, die ein bestimmtes Projekt…
