Far as I know with the lm3875 and LM3886 class A-AB study classes have previously LM3886 did the difference between the two is one of the circuit between the simplicity and the other LM3886 in the bass than the one in the foreground and a strong, LM3875 the bass and other details evenly dispersed.
Circuit of the box, etc.. in components of the I did, usually amp box as use aluminum parts Soon I’d do class A amp copper for the’ll try the circuit feeding a conventional bridge rectifier, power capacitors and more linear voltage to achieve, one coil’ve added. More precisely, the full name of the filter cake “p”-type filter.
Half did not have to heat problems as seen in the photographs I used a pretty big cooler, but as far as I remember in the LM3886 and 3875 integrated thermal, short circuit protection features such as dc-ac current.
LM3875 Gain Clone Amplifier PCB schematic
LM3875 High Performance Audio Power Amplifier
- 56W continuous average output power into 8ohm
- 100W instantaneous peak output power capability
- Signal-to-Noise Ratio >95dB (min)
- Output protection from a short to ground or to the supplies via internal current limiting circuitry
- Output over-voltage protection against transients from inductive loads
- Supply under-voltage protection
- 11 lead TO-220 package
- Wide supply voltage range: |V+| + |V-| = 20V to 84V
Published: 2008/12/08 Tags: audio amplifier circuits, ic amplifier
Simple FM Transmitter Circuit 9V 100-150m
A simple FM transmitter circuit powered by a 9 volt battery pretty small SMD resistors used in PCBs
