Symmetric Power Supply circuit 10A LM337 LM317 Adjustable Voltage
| February 29, 2024 Updated
Symmetric Power Supply circuit per channel 5 amps powering a total of 10 amps voltage control LM317 (negative – at the LM337) is done with LM317 1 amp works fine but the output BD911 BD912 transistors with a strengthened 5 amps made ​​to give filter capacitor, diode bridge and the main circuit all in one pcb on 5Amp Voltage Adjustable Symmetrical Power Supply circuit
lm3317-voltage-adjustable-symmetrical-power-supply-circuit-lm337
LM317 LM337 symmetric power supply pcb eagle Schema files:
Published: 2011/07/27 Tags: , ,
4 Comments “Symmetric Power Supply circuit 10A LM337 LM317 Adjustable Voltage
    Triac Dimmer Circuit 10kW BT139
    10kW 6 BT139 TRIAC dimmer circuit by connecting the power line were raised cardiac dimmer circuit (BR100) triggered 1Mohm can be adjusted by a potentiometer. Triac for cooling medium size fin coolers and 12v dc fan was used in practice cooler box contact to the absence of a triac in the installation of isolator was used half deficit to be used or cooling any part in contact with where they do isolators should be used
    Triac Dimmer circuit
    1. J cJ c
      I noticed that R1 is connected to the output of the regulator as is normal but in this case I would have thought that it should be connected to R13 at the output giving better performance/ stability as it controls the output, taking into consideration the voltage drop across the two emitter junctions and the variable load conditions .
  2. ANTONIO JOSE ANSELMO SEQUEIRA ALMEIDAANTONIO JOSE ANSELMO SEQUEIRA ALMEIDA
    Dear Sir,
    I im trying to make this circuit and downloades the file , however it is password protected and I can noo find the password. Do you still have it ?? Can you share ??
    Many tahnks
    Antonio Almeida
