LM2575 is quite popular in many applications use shared circuit 5v 1 amp output is crafted with a quality printed circuit board drawing of the eagle got engaged at the end of your name that used the sheath to263-5 LM2576-5 States that the same output voltage the output voltage can be adjusted with the “adj” version of the chip.
LM2576 LM2576HV Series
The LM2576 series of regulators are monolithic integrated circuits that provide all the active functions for a step-down (buck) switching regulator, capable of driving 3A load with excellent line and load regulation. These devices are available in fixed output voltages of 3.3V, 5V, 12V, 15V, and an adjustable output version.
Source: digitalspirit.org/wiki/projets/regulateuradecoupageembarque Alternative link:
Published: 2011/03/12 Tags: dc dc converter circuit, power electronic projects, simple circuit projects
Simple Development Board ATmega32 Breakout
ATmega32 Development Board circuit You can use your studies with ATMega32A software to try a simple experiment, the test card 5v supply and have all the input and output ports for external programming socket terminal connected to the reset button. Printed circuit board with Altium Designer.
