LED Wall Washer quite popular very sophisticated applications , there are those made in larger sizes will share the cost of the circuit can be used for small-scale jobs is low and it is easy to make . There are an average of 65 LEDs on the circuit . Circuit 12V DC and is working with the third line of logic has been designed with LEDs in series . McD and will use half- angle of the LED is very important. Wide angle for close distances you can use to narrow angle LEDs .
Power LED based on cost advantages are very low and there is no overheating problem . Power LED light does not give up even benefit your business in many applications . Circuit is modular . According to your request and commissioned more than one side by side, combining the power of light and can increase domain .
Note: I’ve used the resistance value in the circuit LED current 20mA and 150 ? 10mA LED current is resistor vicinity of 330 ? You can use the general vicinity resistor 12v 3 series LEDs and a resistor connected to work , I hooked up the second series resistor after the LED is not an error in this connection by the LED kalitelite will not have any trouble . General LED signage is also done this way .
Printed circuit board on A4 paper can SIMA . A5 piece of paper can remove or 2 , you can press the PCB .
LED Wall Washer ares proteus pcb file:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19947.zip
Published: 2012/11/10 Tags: analog circuits projects, led projects, simple circuit projects
3W Power Led Driver Circuit (PWM)
3w power led drive prepared for the circuit uc3842 and uc3845 PWM control ICs prepared with two circuit diagrams ™ connectivity first circuit uc3842 used two LEDs connected in series, the power MOSFET is irlz24n other 3w LED driver circuit, the u3845 is controlled by 10 LEDs connected in series in this circuit that extend MOSFETs If irf3205 circuit input voltage 10v …. 30v between the 3w power LED driver circuit implementation of the picture does not appear in, but MOSFET small with a cooler, I suggest using .. The first circuit current limiting resistor (R4) account 1v/ak my result according to the resistance to be used writes resistance of the power of the say that there should be less than 0.5W
LED-Beleuchtung Wall-Washer
LED Wall Washer sehr beliebt sehr anspruchsvolle Anwendungen, gibt es diejenigen, die in größeren Größen gemacht werden teilen die Kosten der Schaltung kann für kleine Aufträge verwendet werden, ist niedrig und es ist einfach zu machen. Es gibt durchschnittlich 65 LEDs auf der Schaltung. Circuit 12V DC und arbeitet mit der dritten Logiklinie wurde mit LEDs in Serie entwickelt. McD und wird Halbwinkel der LED verwenden ist sehr wichtig. Weitwinkel für Nahdistanzen, die Sie für schmale Winkel-LEDs verwenden können.
Power-LED auf Basis von Kostenvorteilen sind sehr niedrig und es gibt kein Überhitzungsproblem. Power-LED-Licht gibt nicht auf, sogar Ihr Geschäft in vielen Anwendungen profitieren. Schaltung ist modular. Entsprechend Ihrer Anfrage und beauftragt mehr als eine Seite, die Macht des Lichtes kombinierend und kann Domäne erhöhen.
Hinweis: Ich habe den Widerstandswert in der Schaltung LED Strom 20mA und 150 verwendet? 10mA LED-Strom ist Widerstandsnähe von 330? Sie können die allgemeine Nähe Widerstand 12V 3-Serie LEDs und einen Widerstand zu arbeiten, ich den zweiten Reihenwiderstand angeschlossen, nachdem die LED ist kein Fehler in diesem Zusammenhang von der LED kalitelite wird keine Probleme haben. Allgemeine LED-Beschilderung ist auch auf diese Weise möglich.
Leiterplatte auf A4 Papier kann SIMA. A5 Stück Papier kann entfernen oder 2, können Sie die Platine drücken.
