L4970A Switching Regulator IC, bjt transistor mosfet output alone, i.e. without connecting to the 10 amp power can give. Accordingly, in case the other regulator according to the larger entegrelerine (multiwatt15v) L4970A 13.8 Volt 10 amp power supply, the output voltage can be adjusted between 5 k potentiometer as the author out of the 13.8 v 9.14 v and used. Inner diameter of 23.6 mm, the width of the toroidal took off 14.4 mm, height 9 mm diameter L4970A DCDC converter circuit diagram, pcb layout, and Bill of materials.
Also the power supply 0-25v L4970A have adjustable dcdc Source: ok2kkw.com/00003016/step_down_ps/step_down_ps.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18880.zip
Published: 2012/05/16 Tags: power electronic projects, power supply circuit, power supply project
PIC18F46K20 6-Legged Robot Project
6-Legged Robot Project PIC18F46K20 microcontroller and XBee modules based on two robot’s body, legs and so on. parts such as printed circuit boards prepared with a plaque. Processing is easier for plaque PCBs are used in a very robotic projects. PIC18F46K20 prepared by assembly source software. Asm and hex code there. Also ares proteus pcb, isis’s simulation files.
