Stepped and Isolated Dimmer Circuit
| July 2, 2023 Updated
Lamp Dimmer, motor speed, you can use applications such as soldering iron temperature control dimmer circuit
220 volts (AC)’ll be retrieving landing device for control of the isolated dimer 100w Stage. MOC3040 Opto isolated diac provided with a selective process and control triac BT136 used without coolant CD4001 CD4017 integrated use of
CAUTION dimer is working with high voltage circuit capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
Dimmer circuit diagram
izole-dimmer-sema-dimmer-circuit-120x120
Dimmer circuit Part list
R1, R2: 120k
R3: 27k/2W
R4: 10k
R5, R6: 220/0,5W
R7: 510
C1: 220µF/16V
C2: 100nF
D1…D5: 1N4007
D6: zener11V
IC1: 4017
IC2: 4001
Q1: MOC3040
Q2: BT136
T1: BC548
Dimmer circuit pcb layout drawing Sprint-Layout has been prepared with the program free “ Sprint-Layout-Viewer ” with the program can watch, you can get out
Isolated gradual Dimmer Circuit pcb schematic:
Published: 2008/01/13 Tags:
2 Comments “Stepped and Isolated Dimmer Circuit
    RJ45 UTP Cable Tester Circuits PIC16F627 PIC16F84
    RJ45 UTP cable test, there are two different circuits to control the strength of the circuits made ​​with PIC asm code and the PCB (circuit 2) files have our own UTP RJ45 Cable Tester Make your device
    The only difference is almost a one identical circuits used in microcontrollers circuit PIC16F627-04 used a basic passive circuit elements, a few resistors and diodes LEDs
    Lampendimmer, Motordrehzahl, können Sie Anwendungen wie Lötkolben Temperaturregelung Dimmerschaltung verwenden
    220 Volt (Wechselstrom) werden als Landevorrichtung für die Steuerung der isolierten 100-W-Stufe des Dimers verwendet. MOC3040 Opto-isolierter Diac mit einem selektiven Prozess- und Kontroll-Triac BT136 zur Verwendung ohne Kühlmittel. CD4001 CD4017 integrierte Verwendung von
    VORSICHT Dimer arbeitet mit Hochspannungskondensatoranschluss. Vorsicht + – Wenn Sie die Hochspannungspolarität anschließen, kann es zu starken Explosionen kommen, bevor Sie den versicherten Stromkreis mit Schutzbrille betreiben
    Dimmer-Schaltplan
