Before “Hip6601 with a simple induction furnace” shared a simple induction heater circuit article mentioned has already been experimenting with ir2153 🙂 is a pretty strong circuit ir2153 max4420 high speed mosfet driver with 6 amp outputs amplified after the driver outputs in this way are the provincial essays of 500 volts 30 amps ixfh30n50 HiPerFET power mosfet is connected.
Source: icct.ru/Practicality/Papers/30-03-2010/Invertor-01.php
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18398.zip
Published: 2012/01/22 Tags: power electronic projects
Wind Turbines and Solar Panels Charge Control Circuit
Solar panel, wind turbine electricity production with free energy issues are very popular a few article for charging different circuits I shared this practice wind turbines and solar panels are used together control circuit is simple but links work a little complicate , but plenty of pictures there by carefully examining the system is solved also ” dummy load” I suggest you pay attention to some far as I understand ( I did not bother with these things . ) from the grandstand section spends more energy when this energy
Hochleistungs-Induktionsofenschaltung IR2153 IXFH30N50 Mosfet
Bevor “Hip6601 mit einem einfachen Induktionsofen” einen einfachen Induktionsheizkreis teilte, experimentierte der erwähnte Artikel bereits mit ir2153 🙂 ist ein ziemlich starker ir2153 max4420-Hochgeschwindigkeits-Mosfet-Treiber mit 6 Ampere-Ausgängen, nachdem die Treiberausgänge auf diese Weise verstärkt wurden Provinz Essays von 500 Volt 30 Ampere ixfh30n50 HiPerFET Power Mosfet angeschlossen ist.
