Via the Internet IPcam camera as in the image to get an application done .. A simple circuit with the computer’s LPT port elsewhere on the computer connected to the camera with servo motors control (left, right, up, down) is the image Retrieving main materials video output, which camera and the TV card monitoring program tv card out get the image LCT port sends commands the servo-checking program 5588 on port communicating .. to the host computer via the browser that is being accessed (wwwhome folder index.html) wcam.exe if the server is acting as
Source: maltepoeggel.de/?site=netcam alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18258.zip
Published: 2012/01/03 Tags: analog circuits projects
Li-ion battery 3.6V charging circuit
Li-ion battery charging circuit is a simple structure with a MOSFET and BJT transit are on the provider via USB can be fed or adapter operated, particularly printed circuit design and PCB plate prepared with the battery compartment’s very smart R7 and R8 resistors output voltage adjusts these resistors 1% tolerance to use it is very useful;) LEDs on the circuit goes off after the battery is full ..
