Electronic Ballast Desing Program
| August 21, 2023 Updated
IR International Rectifier company produces quality products particularly to the issue of power electronics MOSFETs. SMPS, PWM drives, etc.. They may be used in addition to electronic ballast circuits produced IR, IRS integrated ballast design programs have prepared for
What is Electronic Ballast
An electrical ballast is a device intended to limit the amount of current in an electric circuit. A familiar and widely used example is the inductive ballast used in fluorescent lamps, to limit the current through the tube, which would otherwise rise to destructive levels due to the tube’s negative resistance characteristic.
Ballasts vary in design complexity. They can be as simple as a series resistor or inductor, capacitors, or a combination thereof or as complex as electronic ballasts used with fluorescent lamps and high-intensity discharge lamps.
About Ballast Design Program Summaries
Tasarım yapılabilen entegreler
  • IR2156 (CFL Balast)
  • IRS2166D (Tek entegre balast)
  • IRS2168D (Tek entegre balast)
  • IR21592 (Dimmer balast)
  • IRS21571D (Balast)
  • IRS2158D (Dimmer balast)
  • IR2161 (Halojen kontrol)
  • IR2520D (Balast)
  • IRS2530D (DIM8 Balast)
Ballast Design Usage Information
The program is easy to use after installation “Ballast Design V4” click on the shortcut you are running a window opens, as in the picture below
ir-balast-desinger
Note: If there is no icon on the desktop shortcut to C: \ Program Files \ Ballast Design V4 \ Run bda.exe file
The program automatically according to the settings you can make on the menu is made up of ballast designs
IC: Integrated choice section
Input: The input voltage
Lamp: Lamp wattage and model
Configration: Parallel serial connection
If you want the “Advanced” section, you can create a detailed design for a person skilled in this section, all values ​​can be entered manually
ir-component-balast-calculaton
All settings made ​​”Desng 5″ button is clicked, then the circuit diagram, bill of materials, ballast, transformer core data, the frequency of the voltage curve, it looks like the info in a new window
IR2156-Circuit-Diagram-balast-devresi-150x150 LPFC-Inductor-balast-induktator-trafo-150x150 simple-current-irl2156-balast-150x150
Ballast Design Notes tips
Also a very good feature of the program design should also add to the PFC circuit and transformer core accounts of the PFC circuit is used for making integrated PFC L6562 ST Microelectronics products
IR2156-elektronik-balast-l6562-pfc
The program is very successful, especially transformer calculation or other control systems can be used to integrate other calculations can be useful in preparing their programs according to their own integrated company but a different account can be used to integrate the transformer run at the same frequency.
In experiment once bda.ex to Operating the program when the operation of the saw in the task manager seems to be working, but it was gone this type would be a problem if the C: \ Program Files \ Ballast Design V4 \ in the config.ini file, delete the program will run smoothly again ini file to create
  • 5-Step Ballast Design
  • Lamp Browser
  • Design Browser
  • Advanced Display Page
  • Ballast Operating Points Calculation
  • LC Tank Component Calculator
  • Ballast Operating Points Graph
  • IC Component Calculator
  • Time Domain Graph
  • Inductor Designer
  • Windows-based Graphical Interface
  • PFC Component Calculator
  • IR2156, IR21571, IR21592, IR21593, IR2166, IR2167, IR2520D, IR2161, IRS2158D, IRS2166D, IRS2530D Component Calculator Schematic
  • Bill of Materials
  • Electrical Data Table
  • Inductor Specification Sheet
  • Component Value Table
  • Operates on Windows XP and Vista
source irf.custhelp.com Ballast Design program alternative link
Electronic Ballast Desing Program dw link
Published: 2009/08/30 Tags:
2 Comments “Electronic Ballast Desing Program
    AutoCAD Electrical Projects DWG Files Big AutoCAD Archive
    AutoCAD electrical projects collected from various sources on the web archive elevators, lighting, plumbing project’s source a lot of AutoCAD. Dwg dosyalarıda There compilation and sharing that is muratkos of electro techno forum. Thanks to those who contributed to preparing
  2. KBVKBV
    Hello.
    Can I use this program to build a ballast for IR2153 ?
