Line following robot design in two different models, one that’s “Baby Orangutan B-328 Robot” control module based on this on the module tb752a1 motor drive and ATMEGA48 or ATmega328 microcontroller’s All materials SMD because it is quite small and lightweight happening robot’s supply 1 pcs 3.7v lithium to raise the voltage of the battery polymer battery and charger provided with a separate converter module used in dcdc
Baby Orangutan B-328 module and the C source code of the printed circuit robotomy line following robot body, and drawing information there. Roboto’s finished state which pretends only 108 grams and is moving very fast.
The other is the pic16f877 in design, 12 PCs cny70 sensors used sensor card, check card schema, pcb and the C source code there are other very fast light not by design
Source: http://webdelcire.com/wordpress/archives/350/ all files alternative link:
Published: 2011/05/01 Tags: microchip projects, microcontroller projects, pic16f877 projects
Robotic ARM Project PIC16F877 CCS C VisualBasic Computer-controlled
The robotic arm project and all resources are quite detailed PIC16F877 microcontroller in the control unit in the project has been kullaıl communicate with the computer is done via the RS232 serial port interface program with Visual Basic has prepared a nice pic ccs codes written in c.
