Metals used to melt induction Furnace in the system in a similar circuit .. Control floor hip6601 MOSFET driver used the circuit operating voltage of 12 volts DC writer drive, MOSFETs an old AMD motherboard scrap and ripped the coil chassis connected to the end 820nf 400v capacitor connected in series have additional current transformer using have made a simple LED indicator. HIP6601 driver number 3 made with input leg 74HCT4046 1 Hz – 10 MHz oscillator output is connected may kuyllanıl oscillator instead of 555 l.
Source: http://rayer.ic.cz/elektro/indheatr.htm
Published: 2011/10/29 Tags: dc dc converter circuit, power electronic projects
Handmade Led Bonsai Tree
The LEDs according to the imagination of the person with a lot of things can get good work süslenebiliyor in this copper wires (coated) with LEDs, beads, using solar power light led bonzayi tree. The leaves of the tree consists of beads of green boncoklardan 1 ultra bright green led hiding between the simple circuit used to regulate placing boncukarın can be added to a variety of effects circuits according to demand.
The body of the tree, complete with copper wire can be pretty valuable copper weight if the account tree:):), there’s little more polite applications flowers etc.. Has been a good deal of fun
