Software Hi-Tech C language prepared by the various applications of electronic sections PIC18F452 PIC16F877 PIC18F4550 based on the Hi Tech C source code and the PCB drawings and all other documents have been shared, LCD character graphics used for the conversion in the programs are
Graphic LCD display 240×128. T6963 controller
Graphic LCD display 240 * 128. T6963 controller. The display is controlled by a 18F4550. The usb is not yet managed. This screen comes from diffusion in Electronics (reference TX-1741-C3M Toshiba).
Graphic LCD KS0107B PIC18F452
Routines in ‘C’ to drive a 128×64 graphic LCD type OGM64GS12D / OGM128GN15D (Orion Display Technology) Lextronic home. This display uses drivers KS0107B + type + HD61203 HD61202 or KS0108B or S6B0107 + S6B0108.
The display is controlled by a PIC18F452.
Winamp LCD PIC16F877
This arrangement allows you to control Winamp from an infrared remote control and display the song title on a LCD 122×32 pixels.
It uses a PIC16F877 connected to the RS232 port of the PC to the infrared receiver. The display is assigned to a graphic LCD 122×32 (drivers NJU6450A or SED1520) with backlight in Selectronic (ref. 41.6026 to 13.50 euro including VAT). This allows to display images of 122×32 pixels, not against it displays text directly, the PIC is responsible; and can display 20 characters (x 4 lines) with 5×7 font and 15 characters with 8×8 font. The PC sends the text and images via the serial port to which the PIC transmits to the display with checksum verification. This solution saves time at the PC that does not have to manage the 5×7 and 8×8 fonts and thus divides transfers by 6-8.
PIC18F452 Nokia 3310 LCD SPI
Nokia 3310 LCD screen LCD focussed Le piloted by un 18F452 SPI soft
source: sjeffroy.free.fr Hi Tech C LCD Examples source code circuits schematic files alternative link:
Published: 2009/09/16 Tags: hi tech c examples, microchip projects, microcontroller projects, pic16f877 projects
Switching Regulators Application Power Supply Book
Maxim electronic circuits used in the various departments a highly integrated manufacturing power supplies for applications to produce integrated application circuits as package in PDF format e-books (Maxim Power Supply Cookbook) for free as distributing started
323 pieces in a wide range of voltage and current switching converter application dcdc (Inverting, Step down, Step-up)’s
Some of integrated control used: MAX1873T, MAX1846, MAX1685, MAX1847, MAX1856, MAX668, MAX8564, MAX1953, MAX8543, MAX1864T, MAX503, MAX1916, MAX1917, MAX1954, MAX1701, MAX669
hola tengo una pantalla g1216 HD61203 HD61202, como seria en proton ide
Hi, Experts are here to help you solve the problem; https://protoncompiler.com/
