Decimal Binary Hexadecimal Calculator and Converter Program
| September 11, 2024 Updated
Hex, bin, dec converter calculation program the microcontroller and for different applications available also in C #, Visual Studio. Net 2005 source code are exe-packed program portable is running (Net framework 2.0 or higher is installed should be).
Hexadecimal-Binary-Decimal-calculation
When working with micro-controller projects, it is often necessary to perform calculations in binary and hexadecimal forms. While almost all calculator tools (such as calc under Windows and gcalctool in Linux) can handle such tasks, they are designed for general purpose calculations and not geared specifically towards working with digital circuits.
Source: Hex/Bin/Dec Converter And Calculator alternative link:
Published: 2011/07/09 Tags:
1 Comment “Decimal Binary Hexadecimal Calculator and Converter Program
    Walking LEDs Circuit 555 CD4015
    Nowadays, LED effects, animations LEDs, LEDs, etc. walking. In applications such as microchip, atmel, etc.. widely used in microcontrollers CMOS, TTL integrated circuits made ​​with a lot of work still gürüy cost, low error rate and so on. more convenient to use for the particular application
    NE555 timer integrated circuit oscillator section is driven by cd4015 made ​​with LEDs. Integrated with transistor output LEDs powered and can be incinerated or more of Kubla opto triac 220v connected lamp can be burned.
