A very well designed specifically for microcontroller projects useful test card can be used in many different kılıflarda integrated standard input output ports that can be used for a long period of time, a plaque is used in high quality card also can be used in large, integrated part of universal tqfp. Finally, there is available an optional printed circuit board according to the double-layer 2
DIP 2,54 mm.
SOIC 1. 27 mm. SSOP 1, 0 mm.
TQFP 0.8 mm – 64/44/32
SSOP 0, 65 mm.
TQFP 0,5 mm – maksimum 64 0,5 mm
SSOP
general resistances and capacitors links
USB, RS232, audio, power, memory card.
SOT23 transistor and regulator connections
0805 and 1206 connections sheath material
s so empty pad.
Source: msevm.com/2011/lab/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18262.zip
Published: 2012/01/03 Tags: pic development board
Lpt Port Camera Control via Internet Servo Motor
Via the Internet IPcam camera as in the image to get an application done .. A simple circuit with the computer’s LPT port elsewhere on the computer connected to the camera with servo motors control (left, right, up, down) is the image Retrieving main materials video output, which camera and the TV card monitoring program tv card out get the image LCT port sends commands the servo-checking program 5588 on port communicating .. to the host computer via the browser that is being accessed (wwwhome folder index.html) wcam.exe if the server is acting as
