PIR Sensor control circuit has three different application circuits LM324, CD4538 used integrated. PR control circuit output control, opto Kubli, relays, MOSFET (right, left) can be used detailed description (in English) and PIR sensor works about the logic diagrams’s circuits RE200B, PIR325 PIR sensors used
PIR motion detector, General purpose motion detector
This motion detector circuit uses a low cost LM324 quad operational amplifier as both a two stage amplifier and a window comparator. Amplifiers IC1A and IC1B have a gain of 100 each for a total of about 10,000. IC1C and IC1D form a window comparator that responds to signals about 200 millivolts above and 200 millivolts below Vcc/2. This window is set by the low current voltage drops across D1 and D2. Comparator outputs feed through D3 and D4 that pass only the positive transitions into CD4538 CMOS single shot IC2 which feeds into Q1 that drives relay RY1.
Direction sensing motion detector This motion detector circuit will both detect motion and indicate the direction that an infrared emitting body is moving. The amplifier and comparator circuits This type of motion detector can be used to indicate people entering or leaving a building or in some robotic applications.
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19888.zip
Published: 2012/10/08 Tags: analog circuits projects
LPC2103 Examples
All the source codes and other related instances of LPC2103 ARM have codes in addition to the LPC2103 test set the scheme also finds
Simple LPC2103 LED blinking LED blinking program for Simple program for LPC2103 LPC2103 by using GNU toolchain under uVision3 IDE, External interrupt example (EINT0) for LPC2103, ILI9320 Portrait example for LPC2103 Simple pure color screen display for inspection, the Demo example for LPC2103 board stack with a 3.5″ TFT LCD module Simple pure color display for screen inspection and PutPixel routine verified
PIR-Bewegungsmelder-Steuerkreis PIR-325
PIR Sensor Steuerkreis hat drei verschiedene Anwendungsschaltungen LM324, CD4538 verwendet integriert. PR Steuerkreis Ausgang Kontrolle, Opto Kubli, Relais, MOSFET (rechts, links) kann detaillierte Beschreibung verwendet werden (in Englisch) und PIR-Sensor arbeitet über die Schaltungen Schaltkreise RE200B, PIR325 PIR-Sensoren verwendet
