FT2232H 93c46 eeporom 10MHz 2 yönlü geliştirme Devresi… FT2232H pcb 10 MHz circuit diagram of eagle pcb board drawing FT2232H Circuit Test Development FT2232H generation of USB devices. The FT2232H is a USB 2.0 Dual High Speed 480Mb/s to UART FIFO IC. It has the capability of being configured in a variety of industry standard serial or parallel interfaces
FT2232H Project Board
FT2232H circuit eagle pcb schematic files :
FT2232H Development Circuit 10MHz Test
Publication date: 2010/09/22 Tags: avr development board
Isolated Triac Control Circuit MOC3020
Triac (btb08-600) PIC controller, CMOS, TTL and so on. With such integrated devices designed to control high power. MOC3020 triac driver photo provided by the motor insulation, such as a lamp devices can be controlled.
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
