Lighting Circuit with White LEDs for Camera
| July 14, 2023 Updated
Prepared for a professional camera, I guess it fits many models. Also, there are examples of pictures taken with led lighting. The circuit works with 12 volts, the control IC HEF4538BP.
Taking very close shots requires the right additional lighting to eliminate the shadow of the lens and gain depth of field by allowing the aperture of the optic to close.
Various methods can be envisaged, for example the addition of lateral flashes, which significantly reduces the assembly and makes it desirable to use an arm or support bracket to ensure stability of the device.
Camera Led Lighting
Ring-Flash-LED
Source: vivelaretraite.allmyblog.com White Led Lighting for Camera PCB schematic alternative link:
Published: 2008/10/27 Tags: ,
1 Comment “Lighting Circuit with White LEDs for Camera
    Graphic LCD bmp2asm fastlcd Font Programs
    Prepare the Microcontrollers with LCD display application provides great convenience to the various imge converter programs
    . bmp format photos for graphic LCD PIC assembly (ASM) as a program that converts source code and Delphi 3 code. exe file there
    BMP to PIC ASM assembly (BMP2ASM)
