KiCAD distributed for free the most advanced PCB, Schematic program .. sometime a few PCB drawing to open kidcad use the program had to examining the features that “PCB Calculator” tool that caught my attention PCB a lot about computation is done a little program has beautiful side Kicad board does away with the portable ..
PCB Calculator program in C: \ Program Files \ KiCad \ bin folder is in the Regulator, Track width, Transline, Electrical spacing, RF Attenuators, Colin code, you can do the calculations Board classes
Regulator in section KD1084, LM317, LM25576, LP2951CM, LT1373 calculations can be done, but for the operation of this section “pcbreg.pcbcalc” file “Regulators data file” section to install the necessary
Color code section of the precision 0.05% to 10% resistance calculation is done ……
KiCad PCB Calculator Program Images
KiCad Gerber Viewer Program
Kicad or other PCB design software to display the gerber files created with a handy tool
Kicad PCB Calculator Gerber View programs :
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22748.zip
Official site: kicad-pcb.org/display/KICAD/KiCad+EDA+Software+Suite
Published: 2014/02/26 Tags: electronics software tools
32 GB EMMC Memory Micro SD card Connection
Hello friends. In this article, we offer you a while ago, I finished the handmade for 32 gb mmc card project page.
First of all, I want to talk about the structure of memory cards. As you know, the market is very different in structure and size, expandable memory unit’s profile is written in Dutch. One of the most known and used, SD (Secure Digital), MMC (MultiMedia Card), micro SD, mini SD, xD (Extreme Digital), CF (Compact Flash), MS (Memory Stick), and M2 cards.
Nützliche Kicad PCB-Tools, Taschenrechner, Gerber Betrachters Tragbare
KiCAD verteilt kostenlos die erweiterte Leiterplatte, Schaltplan-Programm .. irgendwann vor ein paar Leiterplatten-Zeichnung zu öffnen kidcad verwenden Sie das Programm musste auf die Untersuchung der Funktionen, die “Leiterplatte-Rechner” – tool, das meine Aufmerksamkeit gefangen Leiterplatte eine Menge über die Berechnung fertig ist ein kleines Programm hat schöne Seite Kicad board nicht mit der
