In the house of the lamp closer or move automatically according to the combustion designed for precision stable working detector circuit … Author automatically house lights approaching, the motion according to the blink used to have enabled sensors used Sharp is471f (Breakbea’m Sensor Sharp-IS471F) sensor control and other processes used to of the project microcontroller pic12f675 pCB, the source schema asm, hex’s all files. The detector circuit, home automation, smart home and can be useful for your projects.
Source: elektronika.ba alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-16062.zip
Published: 2011/08/27 Tags: microchip projects, microcontroller projects
RGB LED Driver Circuit PIC12F629 PWM
RGB LED driver circuit can be controlled with PIC12F629 pic12f675 As an alternative, can be used PIC12F683 PIC GP0, GP1, GP2 STP36NF06 in output MOSFETs are driven by PWM technique internal oscillator of the microcontroller is used instead of an external crystal. RGB Led source application software prepared by assembly hex asm code, schematics, PCB drawings there.
