Author fluorescent deteriorating energy saving lamp electronic power board to assess these additional driver card have made objective robust power board with power LEDs (EDEX-3LA1-E1) to run … for that power board transformer addition to the 14-lap winding adds this already across the grid had enough space.
Received after winding voltage-controlled MOSFET pointed the opamp (LM393, IRLMK6401) spend LED current limiting circuit is running ..
A similar method used TV or monitor tubes used for I no longer shock Do not store it worked EHT transformer additional windings whether the Flemish data were sometimes SMPS transformer in addition to had to do a simple module to run those were the hey …
PCB drawings that you see in the image given circuit pcb layout can open the file in addition to the classic sprint with the capacitor voltage operated circuit LEDs have overthrown his drawings and diagrams given in the pcb ..
attention Circuits has been working with high voltage capacitor connection Observe caution + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
source: radiokot.ru/lab/hardwork/69/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21195.zip
Published: 2013/03/02 Tags: led projects, power electronic projects, smps circuits, smps projects, smps schematic
Electronic Component Inventory Tracking Program
Open source component library inventory software is simple and very handy and can be customized so that the usage area expands upon request materials added to the name, openness, as well as the computer in the datasheet file or datasheet internet connection can add materials can classify the business the bright side source C + + code through there you can develop … program does not require installation win7 and is working on xp (in the bin folder “to comporg_win.ex” will be executed
Energiesparende Leuchtstofflampe Leistung LED-Treibermodul
Autor fluoreszierende verschlechternde Energiesparlampe elektronische Power-Board zur Bewertung dieser zusätzlichen Fahrerkarte haben objektive robuste Power-Board mit Power-LEDs (EDEX-3LA1-E1) zu laufen … für diese Power-Board-Transformator neben der 14-Runden-Wicklung fügt diese bereits über Das Raster hatte genug Platz.
Empfangen nach Wicklung spannungsgesteuerter MOSFET zeigte den Operationsverstärker (LM393, IRLMK6401) verbringen LED-Strombegrenzungsschaltung läuft.
Eine ähnliche Methode verwendet TV-oder Überwachungsröhren für I nicht mehr Schock verwendet nicht gespeichert EHT Transformator zusätzliche Wicklungen, ob die flämischen Daten waren manchmal SMPS Transformator zusätzlich zu tun hatte ein einfaches Modul zu laufen, die waren die hey …
