Hi Friends,
In this article I will mention the use of incremental enkoderlerin. These encoders with precisely how to angle measurement or position determination to do it.
Market the Absolute (absolute) Encoders and İncremental (Incremental) Encoders, including two types of encoder.
Absolute Encoders, they give different outputs for each position. This type of enkoderlerde Gray and Binary, including among themselves are divided. There is no difference between them in terms of communication. The only difference is the encoding. Although the parallel market is usually the Absolute enkoderlerin outputs 0-10V analogue output models are available.
The biggest advantage of this enkoderlerin even protects the position of the encoder output which is observable. The negative side is that the prices are more expensive.
2. incremental encoders on the market as is used. This type of encoders, Absolute Encoders in parallel output. The encoder produces a square-wave signals are similar in every position. İncremental encoder resolution determines the sensitivity factor, in other words enkoderlerde encoder PPR (pulse per rotation). This value is how much higher the encoder so delicate.
The following illustration shows the incremental encoder, Absolute Encoder, you can see the difference between.
Encoder, angle measurement circuit
Encoder use and protractor project CCS C Proteus isis simulation and PCB files:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-22686.zip
Published: 2014/02/21 Tags: microchip projects, microcontroller projects, pic16f628 projects
Simple shaking machine for printed circuit acid pool
Printed circuit board PCB pressure yaptıkdan after a lot of people, myself included, to melt the copper plaque perhidrol the spirit of using this mixture a mixture of salt and very harmful if inhaled timing how long you estimate it might break if mixture appears in the way copper machine will be very beneficial to your health. I have a machine to do as soon as possible, but not a break. Mechanical system can be designed according to the simple control circuit.
Encoder Winkel-Messung CCSC Pic16f628 Beispielanwendung
Hallo Freunde,
In diesem Artikel erwähne ich die Verwendung von inkrementellen enkoderlerin. Diese Drehgeber mit genau, wie Winkel-Messung oder Positionsbestimmung zu tun.
Markt die Absolute (absolute) Drehgeber und Incremental (Inkremental) Encoder, einschließlich zwei Typen von encoder.
Would you Remind me Your Password for ZIP
320volt.com
