Electronic Fuse Circuit
| June 30, 2023 Updated
Alternatives to Classic Fuse With this circuit can protect the power supply and other devices. If the set current limit is exceeded, or if the output short-circuit protection and to GES. Short-circuit automatically turns off when the current is applied to the circuit.
Circuit voltage of the relay will be equal to the supply voltage. Not just another circuit voltage is 12v can use. Please use 100uF capacitors do. their use voltage to the supply voltage must be appropriate. Please bulamassa BRX46 the circuit thyristor C106 can use it to place.
Electronic Fuse Circuit Schematic Diagram
electronic-fuse-elektronik-sigorta
10k potentiometer is done with the current setting. If you use a very large current in the circuit in circuit 0R6 5W resistor value küşült your health 0R47, 0R33, 0R22, 0R1 can use values ​​like. According to Wu, the current value must be greater. You can also add the display shows the circuit shorted. If you connect to the relay coil shorted LED or lamp light warning when you are getting.
Electronic Fuse Circuit proteus ares pcb files:
Published: 2008/01/12 Tags:
2 Comments “Electronic Fuse Circuit
    Stepper Motor Control Circuit with PIC16F84A mosfet
    PIC16F84 stepper motor control circuit is the button to the right to the left button is pressed, the motor rotates continuously in the opposite direction to the right Doderer stop button will stop the motor.
    The engine speed is adjusted by changing the setting of a frequency crystal oscillator RC oscillator instead of the value of resistor R is connected and changing the speed setting that can be added to potl
    Stepper motor driver circuit diagram
    Elektronischer Sicherungskreis
    Alternativen zur klassischen Sicherung Mit dieser Schaltung können Sie das Netzteil und andere Geräte schützen. Wenn die eingestellte Stromgrenze überschritten wird, oder wenn der Ausgang kurzgeschlossen ist und nach GES. Der Kurzschluss wird automatisch ausgeschaltet, wenn der Strom an den Stromkreis angelegt wird.
    Die Stromkreisspannung des Relais entspricht der Versorgungsspannung. Nicht nur eine andere Stromkreisspannung ist 12V verwendbar. Bitte verwenden Sie 100uF Kondensatoren. ihre nutzspannung muss der versorgungsspannung angemessen sein. Bitte bulamassa BRX46 die Schaltung Thyristor C106 kann es zu platzieren.
    Schaltplan der elektronischen Sicherung
