The LEDs according to the imagination of the person with a lot of things can get good work süslenebiliyor in this copper wires (coated) with LEDs, beads, using solar power light led bonzayi tree. The leaves of the tree consists of beads of green boncoklardan 1 ultra bright green led hiding between the simple circuit used to regulate placing boncukarın can be added to a variety of effects circuits according to demand.
The body of the tree, complete with copper wire can be pretty valuable copper weight if the account tree:):), there’s little more polite applications flowers etc.. Has been a good deal of fun
Simple solar panel, regulator circuit;
Source: hawelson.blog.cz
Published: 2011/10/29 Tags: led projects, simple circuit projects
Simple Transistor Fan Speed Control Circuit
Fan speed control circuit 4 bc639 transistors are used on the circuit speed can be adjusted with potentiometer 47k. Intel CPU fan circuit used in the circuit tests based on phenolic hole about a new simple circuit for the low cost ..
