Shares were held in high voltage flyback more professional, but this application is simple to use transformer driver schematic drawing pictures very clearly understood well prepared. The logic is simple EHT transformer outside of the core .. 5 round wires insulated wire hemmed and driver circuit bağlaıy transformer at the output of the high voltage Retrieving EHT transformer MOSFETS, 555 l of the circuits can also use the transformer of the old tube and Television, monitor hurdalarındn be taken.
CAUTION flyback transformer output circuit produces very high voltage connections Beware + – If you connect the high voltage polarity may be large explosions, can be multiplied circuit before running the insured Electricity Line, Use protective glasses
Source: powerlabs.org Alternatif link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18015.zip
Published: 2011/11/27 Tags: power electronic projects, simple circuit projects
200W Amplifier Circuit TDA2030 New PCB
2 Piece TDA2030A output power transistors connecting the power upgraded 200w amp circuit We all know I think this circuit, the first in 2000 Elektor I saw it in a long thin pcb printed circuit drawings had worked fine had in fact circuit the purpose of making my hand on my transformer was to evaluate the circuit from a single source because it runs my business had arrived circuit 12v … .36 v between supply and can run, but 12v and the efficiency is not good work best 24v …. 36v from happening suggestion at least 20v power use
