Microchip 16-bit Embedded Design Contest Determining Surface Roughness By Laser Light Backscatter Registration Number – MT2254 October 16, 2007 As a stand alone measurement system with user interaction, the project needs some sort of intelligence. A Microchip brand dsPIC microcontroller was chosen to provide this intelligence.
A microcontroller can be described as a microprocessor, but with a high integration of memory and peripherals. The dsPIC30F3013 had all the memory and peripheral needed to control this project on-board. The schematic was created in Orcad Capture 10.5
The dsPIC30F3013 variant was chosen specifically for its 12-bit analog to digital converter and pin count. Each of the 28 pins of this device was consumed in the development and deployment of this project. The 12-bit ADC peripheral handles the conversion of an analog voltage to a 12-bit representation of the voltage. Author: Gregory Cloutier
Published: 2010/05/24 Tags: dspic projects, microchip projects, microcontroller projects
dsPIC30F2012 pulse oximeter 2X8 character display
Signal to H-Bridge used to control IR Source On/OFF {1/0} Connects to T1IN of MAX232 device. Provides RS232 data output for system. SPI Serial Data Output pin that connects to the Microchip MCP4822 DAC device SPI Clock Output to Microchip MCP4822 SPI DAC device
SPI-DAC A Microchip MCP4822, Digital to Similarity Converter with SPI port and interior action connects the dsPIC30F soul to the buffer amplifiers. This emblem takes a 12 bit bid over the SPI attach. The SPI is falsehood for a 16 bit express transfer using a 7.3728MHz clock.
