Calculation of Body Length with 8051 and DS89C430
| Updated on July 9, 2023
In this project, which is designed using DALLAS DS89C430 microcontroller (in simulation AT89C51RC2) circuit and a marching band, calculated on the length of the body, the LCD display was performed.
Circuit consists of three parts.
In the first part, designed with the supply voltage for regulating the voltage source 7805 is used.
In the second part of the object on the moving walkway Fototransistörl sensor for detecting the sensor circuit can be used.
The third part of the circuit consists of a portion of the 8051 microcontroller and LCD.
cisim_hesap_sunu
DS89C430 Programmer Circuit
dallas_programmer
protokolu_-max232
at89c51rc2_cisim
dallas_mtk
Calculation of Body Length with 8051 and DS89C430 keil source code proteus isis simulation schematic
Publication date: 2008/05/19 Tags: , , ,
1 Comment “Calculation of Body Length with 8051 and DS89C430
    Guitar Effects, Pedal, Bypass Circuits
    There are various simple, easy-made guitar effects circuit diagram pcb completed and completed the majority of applications, especially in cases where there’s photos simple wiring diagrams makes your job easier;)
