Development Board PIC 40 PIN
| Updated on April 28, 2020
PIC Development Board 40 is a PIC family MCU development kit in standard I / O format IDC-10 which is separated into PORTA, PORTB, PORTC, PORTD and PORTE.
Using TextTools 40 pin as a MCU MCU, allowing to use both PIC 40,28,18 pins using an adapter
Use electronic switch 4066 to automate programs without having to press a button And able to use PICKIT2 program to work in Auto Import Hex mode with a 20 pin and 40 pin conector, can be used as a emulator / downloader developer In the same body have RS232 onboard, can select port with jumper, can test the software operation without having to connect additional external devices
Or use in the form of Terminal debuger to test the operation And find program errors via PC
There is a USB connector for PIC that has a USB port such as PIC18F4550, PIC18F2550 to test high speed data transfer via USB port
With built-in switching power supply, LM2575T does not overheat and reduces external interference And also can connect to other experimental boards as well. Protel PCB Source
Circuit Schematic 40PIN Development Board
circuit-schematic-40pin-development-board
microchip-pic-development-board-pcb
microchip-pic-development-board-adapter-pcb
Source: thaimicrotron.com
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-26524b.zip
Publication date: 2020/04/28 Tags:
1 Comment “Development Board PIC 40 PIN
    Carte de développement PIC 40 PIN
    La carte de développement PIC 40 est un kit de développement MCU de la famille PIC au format E / S standard IDC-10 qui est séparé en PORTA, PORTB, PORTC, PORTD et PORTE.
    Utilisation de TextTools 40 broches comme MCU MCU, permettant d’utiliser les deux broches PIC 40,28,18 à l’aide d’un adaptateur
    Utilisez le commutateur électronique 4066 pour automatiser les programmes sans avoir à appuyer sur un bouton Et capable d’utiliser le programme PICKIT2 pour travailler en mode Hex Auto Import avec un connecteur 20 broches et 40 broches, peut être utilisé comme développeur émulateur / téléchargeur Dans le même corps, RS232 à bord, peut sélectionner le port avec un cavalier, peut tester le fonctionnement du logiciel sans avoir à connecter des périphériques externes supplémentaires
    Ou utilisez sous la forme d’un débogueur de terminal pour tester le fonctionnement et trouver des erreurs de programme via PC
    Il y a un connecteur USB pour PIC qui a un port USB tel que PIC18F4550, PIC18F2550 pour tester le transfert de données à haute vitesse via le port USB
    Avec une alimentation à découpage intégrée, le LM2575T ne surchauffe pas et réduit les interférences externes. Il peut également se connecter à d’autres cartes expérimentales. Protel PCB Source
