IR Distance Sensor circuit cd4011 multi-zone (2-input 4 x NAND) based on the sensitivity can be set with potentiometer 1 k on the circuit. Various robot can be used in different applications, alarm projects or a simple useful circuit also has proteus schema and ares pressure circuit.
Pictures of the circuit
Source: nabilkarami.com/projects.php?show=project&id=3 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-18717.zip
Published: 2012/03/22 Tags: analog circuits projects
8-Channel RF Relay Control Circuit RS232 PC Pic16f628
Relay control circuit is built on a computer via the rs232 port com pic16f628 microcontroller RF modules (433 mhz) can be controlled wirelessly with 8 relay with rs232 communication max232 project belongs to isis simulation and ares pcb drawings source picbasic codes. One of the buttons while the other two have the control program with sound control. No information about the volume control button on the project, which has been tested.
Hi, kindly can I have the circuit diagram? Thanks Simon
Hi,
pass: 320volt.com
