18 pin 28 pin 40 pin microcontroller series for a very pic usb rs232 multi-purpose development, test circuit ISCP has links with the on-board outputs can be connected upside additional apparatus has all the pcb files
The Picmicro Test Boards uses a PCI socket and even had an old PC to tear desoldering it, build super plate Nocturne and then solder the socket made me ponder a compromise, but flexible, which serve with little exfuerzo for common PIC (8, 18, 28 and 40 pins for example) through the socket to pin connector. Thus was born the Multiboard distributing connector ports in 4 combs 12 each, the first would have common inputs and outputs and the rest would be used or not according to CIP.
Picmicro Test Development Boards Project
Source: sergiols.blogspot.com/ Picmicro Test Development Boards schematic pcb files alternative link:
Published: 2009/05/05 Tags: avr development board, pic development board
High Voltage Generation Circuits MC34063 NE555
two different circuits happen to have 555 timer integrated with the structures and mc 34063 switching control integrated with the circuit used in the transformer television or monitor EHT transformer originally intended use in car air filter, carburetor something to do with the car but know much about because I have not figured business people who know from the pictures more or less solves
CAUTION Be careful is working with high voltage capacitor circuit connections Beware + – If you connect the high voltage polarity may be large explosions before running the insured Power Line circuit, protective goggles
NE555 High Circiut Voltage
