Disco effects of the system control circuit PIC16F628 on board but the basic parts 12 volt 100 watt lamp and a magnifying lens (one in the header extend more than you;)) PIC16F628 with stepper motor is controlled certain speed and direction of the motor rotation is provided motor connected to the end that colored round piece 12v 100w lamp light is reflected light returning from the magnifying lens magnification, as seen in the video processing creates a beautiful image.
Prepared for the safe box security camera system is very similar to the closed type …
In addition to the file received via the microphone made by pic12c506 disco sound effects circuit operates according to its mechanical, etc. I’ve added. Same parts
Source: elwo.ru/forum/58-211-1 alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19032.zip
Published: 2012/06/09 Tags: microchip projects, microcontroller projects, pic16f628 projects
STM32 Examples STM32 Nokia STM32 Watchdog STM32 PWM
STM32 Kit (stm32 32 bit arm cortex mcu) ones will be useful for a variety of projects in the sample code with the source codes.
STM32 Nokia 6800 display on the lcd screen by using the voltage, temperature information (also can be used in different applications nokia6800 card)
