Before “graphic LCD’s picture Font Programs Bmp2Asm FastLCD” and “Microchip Bitmap Font Converter C30 C32” has more features, this program also shows shared this with hex and bin format in addition to the Visual C # source code conversion can have.
Nokia 6100 LCD menu, 132 x 132, dm176220tt5605 176 × 220, elt240320tp 240 × 320, 16 bit color lcd and a variety of formats..
Source: thaieasyelec.com
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19057.zip
Published: 2012/06/11 Tags: electronics software tools
Timer relay transformerless 555 Circuit
Made with 555 timer integrated timer circuit is supplied from the power supply transformerless transformerless voltage to the circuit drawing too much current is available with leveling . However, where there is a high danger of trying to be very careful with this type of connection is required. R1 , C1, C2, D1, D2 and D3 are the materials which make up the primary feed materials . capacitor study of C1 and C2 D3 12V zener voltage should be 25v and 220v mains voltage will be 1W power resistor R1 lowers the operating voltage must be non-polar capacitor 1uF 400V DC or 275V AC at least should be ..
power supply circuit that determines the effect of the output of several volts is zener D3 . U1 555 timer circuit while the task is to integrate these integrated produced by different companies NE555 , LM555 , etc. . There are varieties are all the same . R4 resistor circuit by varying the duration of the timer can be set or potentiometer can be used instead of this resistor .
