The robotic arm project and all resources are quite detailed PIC16F877 microcontroller in the control unit in the project has been kullaıl communicate with the computer is done via the RS232 serial port interface program with Visual Basic has prepared a nice pic ccs codes written in c.
Motor Driver IC is used as a ULN200A made with transistor drivers. The Source code, as well as circuit pcb printed circuit drawings and the robot arm circuit belonging to the dimensions, the drawings.
Source: www.todopic.com.ar/foros alternative link:
Robotic ARM Project PIC16F877 CCS C VisualBasic Computer-controlled
Published: 2011/05/01 Tags: microchip projects, microcontroller projects, pic16f877 projects
Electronic Calculation Programs (+ Source Code Borland C)
Electronic Calculation programs for Borland C + + source code and all. Exe setup file in case there are 8 preset programs.
Active filter, Converter calculator, Pulse transformers Designer tools, Filter for acoustic system, the LC-filter desing, Parametric stabilizer, Symmetrical multivibrator, Timbre block
The Russian language is the only problem, but I wanted to share the source code that could at least limp 🙂 or someone else makes the translation will benefit everyone
