Computer CPU RAM Display PIC18F2550 microcontroller circuit board on your computer with the USB communication that uses CPU and RAM as% of the value of 2 × 16 LCD screen also displays the time information is also giving. Computer software in C # with Microsoft Visual Studio 2010 HiTech C18 prepared by the microcontroller software source code and all of the eagle pcb circuit, given the diagram drawing.
Source: waitingforfriday.com/index.php/PC_Case_USB_LCD alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19250.zip
Published: 2012/07/14 Tags: microchip projects, microcontroller projects, pic18f2550 projects
Mosfet Amplifier Circuit 800W AV800
Av800 amplifier circuit in the past, I shared a lot of sites, but I did not share on the blog .. 320V AV project from the series 800 watts of power MOSFETS in the control of someone who has 2 different design and MOSFET power stage into separate modules on PCBs and the other one …
AV800 watt MOSFET Power Amplifier circuit
PIC18F2550 LCD Rechner CPU-RAM Anzeige
Rechner CPU-RAM Anzeige PIC18F2550 Mikrocontroller-Platine auf Ihrem Rechner mit der USB-Kommunikation, die CPU und RAM als% des Wertes von 2 × 16 LCD-Bildschirm verwendet, zeigt auch die Zeitinformation wird auch geben. Computer-Software in C # mit Microsoft Visual Studio 2010 HiTech C18 von der Microcontroller-Software-Quellcode und alle Eagle-Leiterplatten-Schaltung, angesichts der Diagrammzeichnung vorbereitet.
