BH1415F stereo FM transmitter integrated based on an FM transmitter device output güçlendr made to a circuit .. FM transmitter used in the RF amplifier circuit 2N5770 (instead NTE108 or other provisions) MRF515 (2N5943 or NTE77) transistors based on the 12v power supply is working with. Author modifying RF amplifier with 10 meters to about 5 miles off the transmitter power has been
The FCC says only 150uV/meter at 10 meters is allowed so I’m guessing any more power than what this has could not be FCC certified and sold at retail outlets nationwide. Example of a complete TuneCast system with all cables attached. RF output power is about 120 milliwatts. Although not verified with this setup previous road tests have shown this much power can be heard up to 3 miles away using an outside 1/2 wave vertical transmitting antenna.
Source: sonic.net/~n7moe/BelkinMod.htm alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19656.zip
Published: 2012/09/08 Tags: analog circuits projects
Scrolling Text Circuit LED Matrix PIC16F628 74HC595
Marquee circuit built on the pic16f628 microcontroller circuit 8 X 80 LED matrix used LEDs is being prepared with the source software assembly circuits 74HC595. asm, cod, etc. have proteus isis simulation file. marquee circuit computer with rs232 interface for the despatch of an advanced case of kom port communicates using the terminal program.
LED Marquee PIC16F628 This unit plays the text on the LED matrix 8 X 80 LEDs, has a memory 128 characters of text, which are loaded from a PC via COM port using Terminal V1.9. The device has all the uppercase and lowercase letters of the Russian alphabet and numbers, and other characters that you can see in the table below. MCU running at 20 MHz and operates the shift registers 74HC595D, that the logic level 1 lights LED matrix rows and decoder full analog controls through 74LS138 amplifying transistor 8-mu columns of all matrices.
BH1415 FM Sender HF-Verstärkerausgang nach oben
BH1415F Stereo-FM-Sender integriert basierend auf einem FM-Sender-Gerät-Ausgang güçlendr gemacht, um eine Schaltung .. FM-Sender in der RF-Verstärker-Schaltung 2N5770 (statt NTE108 oder andere Bestimmungen) MRF515 (2N5943 oder NTE77) Transistoren auf der 12V-Stromversorgung arbeitet mit. Autor Änderung RF-Verstärker mit 10 Metern bis etwa 5 Meilen von der Sendeleistung wurde
Die FCC sagt, dass nur 150uV / Meter bei 10 Metern erlaubt ist, also nehme ich an, dass mehr Energie als das, was sie hat, nicht FCC-zertifiziert und im Einzelhandel im ganzen Land verkauft werden kann. Beispiel für ein komplettes TuneCast-System mit allen angeschlossenen Kabeln. Die HF-Ausgangsleistung beträgt etwa 120 Milliwatt. Obwohl dies mit dieser Konfiguration nicht bestätigt wurde, haben frühere Straßentests gezeigt, dass so viel Leistung bis zu 3 Meilen entfernt mit einer externen 1/2-Wellen-Vertikal-Sendeantenne gehört werden kann.
