Method practicality questionable, but now the most appropriate category “Practical Information” will be earlier in the PCB about the making of articles I’ve shared now the easiest and cheapest method iron is happening with the new I met a brother of mine ever never crossed my mind a method I have used 🙂
Profession has nothing to do with electronics, but ingrained curiosity amp circuits because there is no experience of making PCBs is very difficult for him
The method used by the A4 photocopy paper printouts PCBs drawing circuit size cut on his stiff cardboard box part cut and paste the 🙂 with needle holes paves way by following materials legs can not afford the additional wire combines the following ensbo his TDA2030A bridge amplifier of the photos are
Yes, you see, I first saw it I was very surprised 🙂 Imagine electronic information have no experience, no circuit would make the pcb drawing but PCBs What is the HOW 🙂 Here in this case, carton PCBs idea emerged brother now so accustomed that vas not want to change 🙂
Published: 2010/01/12 Tags: interesting projects electronics
Various Electronic Circuit Diagrams
Earlier Velleman kits circuit diagrams I shared (230 pcs mixed electronic circuit diagram Velleman kits) still a kit manufacturer’s (kitrus) various circuit diagrams’ve reached the circuits most useful simple circuits amp circuits, alarm circuits, led circuits, motor drives, etc.. has many applications.
The circuit diagram in PDF files (no PCBs) list of materials needed work and the material accounting information (in English) is. According to other sources on the Internet as a source for reliable operation of the circuit, such as a very low probability. Here’s a short list did not add them all up. There are 170-odd circuitvrelerin çalışmaması gibi bir ihtimal çok düÅŸük. AÅŸağıda kısa bir liste bulunuyor hepsini ekleyemedim. 170 küsür devre var
