Av800 amplifier circuit in the past, I shared a lot of sites, but I did not share on the blog .. 320V AV project from the series 800 watts of power MOSFETS in the control of someone who has 2 different design and MOSFET power stage into separate modules on PCBs and the other one …
AV800 watt MOSFET Power Amplifier circuit
The 800 Watt AV amplifier is based on My 1kw Amplifier and shares the same topology and basic PCB layout. The only real difference is the number of Output devices that the unit uses. The 1kw design has 20 O/P devices, while the AV amplifier has 14 O/P devices. This amplifier can be used for practically any application that requires High power, low noise, distortion and excellent sound. Examples would be Sub-woofer amp, FOH stage amplifier, One channel of a very high-powered surround sound amplifier etc. The AV amplifier has four main stages of amplification. We will begin by looking at each stage in reasonable detail.
All files belonging to the project AV800 Amplifier:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-19225.zip
Published: 2012/07/13 Tags: audio amplifier circuits, transistor amplifier
24V Switch Mode Power Supply FSFR2100
FSFR2100 Fairchild production of a new generation of very powerful SMPS control driver IC power MOSFET integrated in the complete 300 kHz operating frequency is being used to feed the lcd SMPS circuit televuzyon have but a very ideal for the application.
Switch Mode Power Supply FSFR2100 LCD TV
The evaluation kit for the FSFR2100. It should be used in conjunction with the FSFR2100 datasheet as well as Fairchild application note AN-4151 and technical support team. Please visit Fairchild’s website at http://www.fairchildsemi.com.
800W MOSFET-Verstärker
Av800 Verstärker-Schaltung in der Vergangenheit, teilte ich eine Vielzahl von Websites, aber ich nicht auf dem Blog teilen .. 320V AV-Projekt aus der Serie 800 Watt von Power-MOSFETs in der Kontrolle von jemandem, der 2 verschiedene Design-und MOSFET-Endstufe hat separate Module auf PCBs und die andere …
AV800 Watt MOSFET Leistungsverstärker Schaltung
Der 800-Watt-AV-Verstärker basiert auf My 1kW Amplifier und teilt die gleiche Topologie und das grundlegende PCB-Layout. Der einzige wirkliche Unterschied ist die Anzahl der Ausgabegeräte, die das Gerät verwendet. Das 1 kW-Design hat 20 O / P-Geräte, während der AV-Verstärker 14 O / P-Geräte hat. Dieser Verstärker kann für praktisch jede Anwendung verwendet werden, die hohe Leistung, geringes Rauschen, Verzerrung und exzellenten Klang erfordert. Beispiele wären ein Subwoofer-Verstärker, ein FOH-Stufenverstärker, ein Kanal eines sehr leistungsstarken Surround-Sound-Verstärkers usw. Der AV-Verstärker hat vier Hauptstufen der Verstärkung. Wir werden damit beginnen, jede Stufe detailliert zu betrachten.
