An application for a little research, I found a lot of circuit I had to attiny2313, but because of the lack of material and computer problems, did not provide to take care of my business as soon as possible, be simple:) circuits
At the end of the programmed took the Savior was COM port again attiny2313 electronics diy site to program the ATmega8 shared circuit (arv programmer http://www.electronics-diy.com/avr_programmer.php) Chase was tried with programming attiny2313
AVR ATtiny2313 connection;
Oscillator circuit diagram so that more mixing section without a separate circuit in the diagram above give crystal and capacitors to be connected as shown in the diagram below
Circuit is simple to print circuit preparation directly from the perforated plate formed on this circuit a lot with the hunt can be programmed ATtiny2313 prepared socket, kıristall assembly as well as an additional ICSP output’ve added in the future a different hunting programs if it output connections of whether I use
I need a 5 volt supply circuit in addition to the computer’s USB port adapter you can use if you want +5 v bought.
PonyProg for installation after having used the link in the top menu of the circuit Setup / Interface scroll down to setup the I / O settings Serial programmer, SI Prog API, mark it as COM1
Then again in the top menu, select the type of processor models Sumgia click on the yellow folder and open the hex file “program write-memmory flash” button
Published: 2011/01/16 Tags: programmer circuit, simple circuit projects
Floating Led Circuit Hi Tech C Example
The second is the floating light work. Connect the two types of LEDs to the Pic. In the former case, a source with the port out 25mA. In this case, the graph is connected to the chassis with a pice of the anode resistance. Port 1 is applied to the led lights up. The second type is that in the other end of a resistor, as ledin cathode is the positive voltage with pice, connects to. In this case, the led should only be applied to port 0.
#define LED PORTB
