Very high current of the current transformer and with microcontroller sensitive way measured to be recorded will be useful for source code with 2 sample application circuits one of the Atmel AVR ATMEGA48 88/168-P used) based on the current (4kW) information on the SD card is able to record and chart GLCD the circuit can also view information on LMC6484A, ADE7757, AD623 used in the entegreleri
Other applications made by the software pic16c74 prepared with CCS C program via the PC displays current information
This device monitors household power usage and logs it to an SD card. A simple analog front-end amplifies the signals from voltage and current detectors and an ATmega168 microcontroller computes the power consumption using the formula P=V*I. voltage divider connected to an AD623AN instrumentation amplifier. LMC6484AIN quad op-amp is used for signal amplification.
Power Line Monitor power is calculated with an analog multiplier followed by a low pass filter to obtain the DC component (real power). These analog quantities are then fed to a 12-bit A/D converter driven by a ’77 PIC. The circuit gains get me a resolution of 5 Watts. As a result I can even see the effect of turning on one lamp.
Source: stahlke.org/dan/powermeter (avr) edcheung.com/automa/power.htm alternative link:
Published: 2011/05/11 Tags: avr project, microcontroller projects
BD911 BD912 Transistor 70W Amplifier Circuit
Amplifier circuit pcb printed circuit quite stylish become a regular settlement there the supply voltage at high + – 33 volts symmetrical 4-ohm speakers with a 70w power can give 70w power with a 1kHz signal THD rate of 0.057% (THD Total harmonic distortion-Total harmonic distortion) only on departure coil located 1mm wire 13 to be wound spr … 50mA quiescent current adjustable from 40 to 2.5k potentiometer
