Atmel microcontroller Board with Led indicator wristwatch ATmega32U4 project there is no usb connection and SD card connection, the advanced charging system, piezo sensor, etc. are included in the design of printed circuit boards PCB source code very well, eagle pcb schema files. The previously shared “Atmel ATmega168PA Multi-function Digital Wristwatch” is a much more advanced version of the project.
The main software used in libraries as information;
the display includes display functions h – …
the motor that controls the functions of vibration engine. –.
piezo piezo sensor which controls functions. –.
rtc. h – RTC functions
sd h – csv or dat file installation is required for the functions
source: tictoctrac.com/ alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21982.zip
Published: 2013/08/08 Tags: avr project, microcontroller projects
Line following Robot Sumo Robot, control circuits
Sumo, Line following and robot control card project open source design and very high quality of all resources provided PIC microcontroller code and eagle diagram pcb drawings are especially line following robot prepared for PCB drawing a very good high strong with a system that can go very quickly 🙂
Robot control board previously shared “Rötkönen the” hardware ready style (see: Robot Robot development control board for your projects Rötkönen) PICAXE28X2 AND PIC18F25K22, PIC18F26K22 for use with microcontrollers have two different PCBs ..
Atmel LED-Multi-Funktions ATmega32u4 Uhren
Atmel mikrocontroller-Board mit Led-Anzeige, Armbanduhr ATmega32U4 Projekt gibt es keinen usb-Anschluss und SD card-Anschluss, die die erweiterte lade-system, piezo-sensor, etc. enthalten sind das design von Leiterplatten, PCB-source-code sehr gut, eagle pcb-schema-Dateien. Die zuvor freigegebene “Atmel ATmega168PA Multi-Funktions-Digital-Armbanduhr” ist eine wesentlich erweiterte version des Projekts.
