Digital clock project PCB design is very good and prepared and used according to the coffers of small metal wristwatch. Except for a few digital Wristwatch circuit material including all the elements of SMD type ATmega168PA digital clock project ski asm, eeprom, hex, etc. all code with source PCB layout drawing and the sprint, proteus isis simulation file
Digital Wristwatch circuit features
Clock – calendar:-hours, minutes, seconds, day, date, month, year, day of the week for the date can be displayed, Calculation, automatic summer and winter time (can be changed), takes into account leap years
2. two independent alarms (triggered melody is heard)
3.1-second increments the Scheduler. (Maximum duration 99h 59 m 59s)
4. Timer with two channels that have a resolution of 0.01 sec account. (Maximum operating time 99h 59 m 59s)
5. Account 1sn resolution with a stopwatch. (Maximum duration of use up to 99 days)
6. in the range of-5 ° C to 55 ° C Thermometer (temperature range is limited to the normal situation) with step 0.1 ° C
7. Reader and emulator hardware keys – tablet Dallas DS1990 through type with the ability to display the key code Bytes 1-Wire (I already have a few universal “off-road” memory 50 pieces).
8. Nikon Digital cameras “Pentax”, “”, “Canon” for the infrared rays remote control (only applied to “capture” command)
9. LED flashlight
10.7 ringtones
11. alarm clock (can be changed)
12. check the Voicemail button press (active)
13. the battery Voltage monitoring with Calibration function
14. Digital brightness control indicator
source: diy-blog.ru/mc/mc60.php alternative link:
FILE DOWNLOAD LINK LIST (in TXT format): LINKS-21903.zip
Published: 2013/08/01 Tags: avr project, microcontroller projects
Timer Touch Switch Circuit 555
555 timing IC made ??with a simple circuit than the number 2 pin trigger tip 220nF capacitor out according to the signal pin 3 of the output is rectified and the relay goes to the relay is energized contacts connected device opens or by connection closes two different modes can be
22UF 470k resistor and capacitor values ??can be adjusted by changing the release time of the relay formula 1.1 xrxc values ??are stretched büyüdükc time I’ve used this value when you upgrade 470k for timing relay is prolonged residence time of the towed
Atmel ATmega168PA Multi-Funktions-Digital-Armbanduhr Schaltung
Digitaluhr-Projekt Leiterplatte-Design ist sehr gut und vorbereitet und verwendet entsprechend den Kassen der kleinen Metallarmbanduhr. Bis auf ein paar digitale Armbanduhr Material einschließlich aller Elemente der SMD-Typ ATmega168PA Digitaluhr Projekt Ski Asm, Eeprom, Hex, etc. alle Code mit Source PCB Layout Zeichnung und der Sprint, Proteus Isis Simulationsdatei
