24V 48W Digital Soldering Stations ATmega8
| September 5, 2024 Updated
Electronic Soldering circuit built on the atmel atmega8 microcontroller can be used with a 48-watt soldering iron heat 24 volts and setting the status lcd on the displayed soldering iron resistance BUZ11 mosfet controlled. Digital soldering circuit software written in BASCOM source. bass, have a circuit diagram pcb files hex etc … material, complete with a list of a project
elektronik-havya-lcd-havyalar-24v-48w-solder-atmega-atmel
24volt-48watt-havya-atmega8-lcd-temp
Source: http://paja-trb.unas.cz/elektronika/konstrukce/mikropajka_2011.html alternative link:
Published: 2011/03/15 Tags: , ,
1 Comment “24V 48W Digital Soldering Stations ATmega8
    Calculating PCB Track
    UltraCAD company deploys with this program as a free PCB in the heat of the current-carrying capacity and Alex DLE 70 Professional displays the values. Calculation program does not require installation to work, the file must be in the windows system folder installed vbrun300
    A motor drive circuit of shunt resistance on the pcb according to the schedule made by drawing a circle road:)
