AT89S52 Thermistor Circuit Thermometer LCD Display
| July 5, 2023 Updated
NTC Thermistor Thermometer based on AT89S52 circuit and HIH 3160 humidity sensor humidity and temperature information is given. Display LCD display circuit and there are two versions of the C source code and schema files have been prepared by Orcad.
at89s52_thermistor_thermometer
Thermistor Thermometer: LCD version: The ADC and thermistor circuits are quite the same as the 1st version. The ADC can be LTC1298 or MCP3202. Now with this design, P0 is used to interface LCD bus. SW1 is optional key switch. Since the number of I/O port are not many, we then can replace the 40-pin MCU with 20-pin MCU easily. J2 is available for connecting another sensor. The input range is 0 to +5V. HIH-3160 Honeywell Relative Humidity Sensor
Source: http://www.kmitl.ac.th/~kswichit/thermistorLCD/ AT89S52 Thermistor Thermometer LCD Display Alternative link:
Published: 2008/03/02 Tags: ,
2 Comments “AT89S52 Thermistor Circuit Thermometer LCD Display
    ATMEL AT89 series programmer circuit (working tested)
    ATMEL AT89 series with the circuit programmer can program many microcontrollers. Programming circuit integrated with different number of pins used for two ZIF socket.
    Circuit running through the RS232 serial port of the computer AT89C51-C52-S52 89series4.hex file without installing the integrated scheduler to work. Project of the diagram, pcb printed circuit board, software and computer programs have hex.
    AT89S52 Thermistorschaltung Thermometer LCD-Anzeige
    Das NTC-Thermistor-Thermometer basiert auf der Schaltung AT89S52 und dem Feuchtigkeits- und Temperatursensor HIH 3160. Display LCD-Display-Schaltung und es gibt zwei Versionen des C-Quellcodes und Schema-Dateien wurden von Orcad vorbereitet.
    Thermistor-Thermometer-LCD-Version: Die ADC- und Thermistor-Schaltkreise entsprechen weitgehend denen der 1. Version. Der ADC kann LTC1298 oder MCP3202 sein. In diesem Design wird P0 als Schnittstelle für den LCD-Bus verwendet. SW1 ist optionaler Schlüsselschalter. Da die Anzahl der E / A-Ports nicht groß ist, können wir die 40-polige MCU problemlos durch eine 20-polige MCU ersetzen. Für den Anschluss eines weiteren Sensors steht J2 zur Verfügung. Der Eingangsbereich liegt zwischen 0 und + 5V. HIH-3160 Honeywell-Sensor für relative Luftfeuchtigkeit
